Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Hitec 5000 Gyro and Futaba 7C >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-17-2008, 02:02 PM
Default Hitec 5000 Gyro and Futaba 7C
i have the combo HG-5000 Gyro w/5083 digital servo combo, and a 2.4 GHz FASST 7CH
the gyro is up and running properly, i was just wondering if i did something right, using the gyro menu (in the TX) i put the B switch to 75 up, and 25 down, the switch works properly to change from rate mode to TL mode on the gyro, is this the setting where one would change the gain function of the gyro?, meaning, is 50 centered, and either side of that the gain for rate and TL?
Old 01-17-2008, 04:08 PM
Default RE: Hitec 5000 Gyro and Futaba 7C
solved my own issue, i didnt have the T7C's gyro submenu set to gyro, it was set to normal
now that its set to gyro theres a full 0-100% on each side of the switch and the gyro reacts in sync with that setting
Old 01-17-2008, 08:58 PM
The Hedgehog's Avatar
Good deal, good gyro huh? I have one in my 500 and I like it.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
