Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Short flight time on the 600 Rx li-poly?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-03-2008, 05:09 AM
sherman89
Default Short flight time on the 600 Rx li-poly?
I found that I was only getting 3 flights on the li-poly rx that comes with the 600 before I was down to one green light on the BEC. I replaced the poly and BEC with a stacked 2000 mah 5cell 6vt nimeh pack that I made up and now go 6-7 flights without a problem. Has anyone else have the reduced Rx poly time?
Old 06-03-2008, 10:23 AM
Steve Collins
My Feedback: (8)
Default RE: Short flight time on the 600 Rx li-poly?
I haven't noticed this problem using the stock lipo that comes with the kit.
Old 06-03-2008, 04:11 PM
Fly To Chill
My Feedback: (20)
Hey dude how are you, I get about 5 flights with my 1320TP battery.
Old 06-05-2008, 04:46 AM
sherman89
My 600 is the original aluminium frame so the 1100 li-poly may be just suffering from old age. The 2 on 3 pak at 6vt is working quite well mounted on the bottom rack below the head. I have flown the 2000 6vt paks for many years on airplanes, the weight between the li-poly and BEC is about the same as the nimt pak with no difference in the balance.
