Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Is there a clutch on the blades and gears of an Align 450?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-07-2008, 10:54 AM
bensidus197217
Default Is there a clutch on the blades and gears of an Align 450?
I am as green as the grass on this but I think there is either a clutch mechanism between the driven gear, rotor gear ,and blade mainshaft. If I hold any part steady in my hand I can turn all the others with some slight resistance. Is this normal or should they all be locked together?
Old 06-07-2008, 12:08 PM
Burntt32
Default RE: Is there a clutch on the blades and gears of an Align 450?
there is a one-way bearing in between the main(big) and autorotation/tail drive gear(small). if you spin the blades, the main gear should stay still but the tail gear and tail should spin.
Old 06-07-2008, 05:38 PM
bensidus197217
I'll go try that Thanks
Old 06-08-2008, 08:44 AM
dooleyje
ORIGINAL: bensidus197217
No clutch. Direct gear drive to main gear and oneway to run tail gear. Think of it as a transmission. Just like Burntt32 said.
Have fun
Jim
Old 06-08-2008, 05:02 PM
bensidus197217
Thanks it appears when I try that my Heli does what it is supposed to. At this rate it should take forever for me to figure out how to fly it but I'll have fun trying.
