T-Rex heli For all you T-Rex lovers out there, this where you can post!
600N balance
Old 08-14-2008, 08:38 PM
[]TEX[]
Default 600N balance
I've always assumed this, but is balancing done with tank empty or full?
Secondly, with the tank not directly under the shaft, CG changes as it empties correct?
Old 08-14-2008, 08:54 PM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: 600N balance
Split the difference, do it 1/2 full, that will give you the average.
Yes, rear mounted tanks get nose heavy as the fuel burns off.
Old 08-14-2008, 10:14 PM
[]TEX[]
Are there helis with mid mounted tanks?
Also, do you use a header tank on you 600?
Old 08-18-2008, 10:15 AM
BarracudaHockey
There's probably a few but that causes other problems.
Yes I put a header tank on my 600n.
