Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Need help with servos >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-22-2008, 11:16 PM
Default Need help with servos
what servos are you guys using on the trex I put a futaba s9650 on the tail what sould I use on the rest of the bird. thanks for the help. Thanks steve
Old 10-22-2008, 11:30 PM
Default RE: Need help with servos
hs65mg's for cyclic.
Old 10-23-2008, 07:36 AM
Missileman's Avatar
Second the Hitec HS65MG if you can afford it.
If your budget is real tight you can put on the Hitec HS65HG with the Karbonite gears and upgrade the gear set to metal later.
The metal gears for the HS65 are about $10 a set.
Old 10-23-2008, 08:31 AM
Third for the HS 65's. Whether you do the metal or the karbonite gears you can not go wrong with these servos...very nice speed and durability. I have them in both my TRex 450 and my Gazaur Mars 480.
Old 10-23-2008, 09:01 AM
BryFlyGuy67's Avatar
I use the HS-65MG's on both of my TREX's. They are pretty much the standard. However, both Futaba and JR now have digital metal gear servos for a 450 class Heli as well.
Old 10-23-2008, 11:15 AM
i like my JR DS285 servos for cyclic. they have a solid feel to them. i have been very pleased with they're performance. i am running with a HS81MG on my tail though, and found it to be better than the jr ds3500g i was using on my 450 SA.
Old 10-23-2008, 12:08 PM
One more for hs-65 I have the Hb ones wish I would have went the metal gears as I have stripped the karbonite a few times now. Only in a crash though they are fine for just about any type of flying. If buying new I would also look at the new Hs-5065 which are the Digital version of a hs-65
Old 10-23-2008, 12:24 PM
Missileman's Avatar
ORIGINAL: crimsonrain22
You do know you can replace the Karbonite gears with metal replacements when you strip them?
Old 10-24-2008, 08:26 AM
ORIGINAL: Missileman
Yes, you can.
Old 01-13-2009, 04:59 PM
My Feedback: (29)
stay away from the HS 5065mg they stall easily around 6 8oz (garbage) I have 4 of them
Old 01-13-2009, 07:37 PM
Go straight for the HS-65MG'S !
Old 01-15-2009, 03:26 PM
My Feedback: (29)
I would use the HS65MG's but stay very far away from the 5065MG's
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
