Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Copter X frames for a V2 Trex
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-19-2008, 03:40 PM
heliaction
heliaction's Avatar
Default Copter X frames for a V2 Trex
Can any one tell me if the Copter X frames will interchange with the Trex frames. Both of my lower frames are cracked and if i buy Trex frames i have to buy the whole set, where as the Copter X offers lower and upper sets.
Also i am assuming the main shaft is the same.
Thanks in advance
Old 12-19-2008, 04:08 PM
UTM
Default RE: Copter X frames for a V2 Trex
www.trexparts.com has the upper and lowers seperately I believe. Not sure if the CoX frames will fit or not. If not you may check out the xheli sight. I know for a fact the exi frames will fit. I fly one and have replaced the lowers with align equip and it's a direct replacment. For me my LHS carries the lowers and uppers seperately.
Uri
Old 12-19-2008, 04:29 PM
heliaction
heliaction's Avatar
Thanks for the reply. Is there any difference between the v1 and v2 frames. I am lead to believe the v2 frames are slightly thicker, but i dont think that is a problem in my case especially because it is the lower ones im after. As long as all the holes line up it should be fine.
