T-Rex heli For all you T-Rex lovers out there, this where you can post!
AR6100 Rx
Old 01-11-2009, 04:11 PM
Default AR6100 Rx
Question?
Can I use the "BATT" channel for something other then just binding the heli?
Say maybe plug in an LED light?
Old 01-11-2009, 04:39 PM
Default RE: AR6100 Rx
Yes, you can plug in an LED there. I have the K and B night tail blades and they use an LED. That's where I plug it in.
Old 01-11-2009, 04:57 PM
BarracudaHockey's Avatar
Just make sure whatever you put in there doesn't allow the signal pin to be grounded, that will put the receiver into bind mode. If its just got the + and - then yes, it's just another port on the reciever power bus.
Old 01-11-2009, 07:39 PM
Sweeness!!!!!!
I just use a servo extension and remove the white wire!
Thanks guys!!! I thought I was going to have to use a 7 ch RX.
Thanks again!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
