Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Pictures of your electronics install for TRex 600ESP >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-12-2009, 06:58 PM
My Feedback: (8)
TJPro351's Avatar
Default Pictures of your electronics install for TRex 600ESP
Does anyone have any pictures on their electronic installs for the 600? I would like to see how your installs are, servo wire routing, placement of ESC/Rx/BEC/Gyro control box.etc.
I have a:
CC85v ESC
Quark Pro BEC
611 Gyro
9 Channel Futaba Rx
6S Battery
Battery for external BEC??
Also would like a electrical diagram on how the Quark Pro BEC is wired. I am assuming I have to use a separate Li-Po battery. I know I have to remove the red wire on the ESC because I am using >3 Li-Po cells.
Any other suggestions would be appreciated.
TJ
Old 01-13-2009, 07:27 PM
My Feedback: (8)
TJPro351's Avatar
Default RE: Pictures of your electronics install for TRex 600ESP
Come on guys....I'm sure you have some pictures of your installs. Lets see em!
Old 01-13-2009, 08:13 PM
BoysToys's Avatar
Mine is not an ESP but here are some pics of mine. My gyro is mounted on top of the boom block. My receiver pack is directly behind the motor. My esc is mounted on the right side of the frame with the Align 6A voltage regulator mounted on the left side of the frame. I have my AR7100 mounted on the left side of the frame with the satellite receiver mounted on the right side. My 600 is setup to run on 8S so I am using the Castle HV-85esc and the Scorpion HK-4025 890kv motor.
You can see tons of pics if you go over to [link=http://www.helifreak.com/showthread.php?t=31711]Helifreak TRex 600 pics thread[/link].
Hope this helps,
Brandon
Old 01-13-2009, 09:29 PM
My Feedback: (8)
TJPro351's Avatar
Thanks Brandon...your install looks good. Thanks for the link!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
