trex 450 ESC
PA
trex 450 ESC
Ok, well my ESC no longer arms, it beeps once and thats all she wrote. Is it the ESC? or something else that isn't working? I have crashed and slightly damaged some wiring, but repaired it last year and it has been fine all this year.
I'm wondering if its worth getting a new one? if so which ones are good to use with the stop se v2 motor?
thanks alot.
thanks alot.
FL
RE: trex 450 ESC
check to see if your have any bad solder joints. 35a-40a esc are not that bad in price nowadays. all depends on how much you want to spend. I would get the align 35a esc as mine has been doing great for over a year with no issues. plus it has the best soft start.
MA
RE: trex 450 ESC
Great idea double check your solder joints, but are you flying the Align motor 430 X or XL I had issues with mine after a couple of crashes. I would wiggle the wires to get it to arm. That's where my issues were, & not at the ESC. I finally got fed up and replaced the motor with a Scorpian & not only got better power but reliability also
PA
RE: trex 450 ESC
I'm thinking some wires are loose, because i just pushed on them and it started to arm. thanks for the input though guys. how much are those scorpion motors and whats the size?
