Trex 600 gyro ?
Trex 600 gyro ?
Seting up a ALIGN T-REX 600 Nitro Super Pro Combo which gyro do you think best Futaba GY401 Gyro with S9254 Digital Servo or ALIGN GP750 Head Lock Gyro Combo (GP750+DS620)
or are there better combos ?
Using spectrum DS 821 servos on cylic
FL
RE: Trex 600 gyro ?
if you can afford it the spartan ds760 is the latest and the greatest at the moment.
if I had to choose between the gy401 or the align gp750. Defintely go for the gp750. its much much better than the gy401. I have both.
MI
RE: Trex 600 gyro ?
I agree, Noob. The thing is this: you gotta expect to pay for quality parts. Ido think perhaps my suggestion of the 9256 for the tail is overkill. The gyro is probably overkill, too but it can be found for around $169.99 so it's not that bad.
Scott
Scott
RE: Trex 600 gyro ?
Cheers for that guys, due to budget I think this combo is the way I am heading ALIGN GP750 Head Lock Gyro Combo I can pick one up for $ 187 us
The spartan sounds like the gear with the GP 750 a close match. I have a 450 pro with the gp750 so at least I already know the set up. This is the first nitro set up so should be interesting to get the needle mix right. I have seen problems getting the throlte curve and pitch right so you have a good head speed
RE: Trex 600 gyro ?
Has anyone used one of these starters http://www.helipross.com/align-super...-hfsstq01.html
They say they are good for 500 starts
CA
RE: Trex 600 gyro ?
ORIGINAL: basman
Here are just a few threads I found about the DS821 with a quick search. You might want to read these in their entirety.
http://www.runryder.com/helicopter/t...ighlight=ds821
http://www.runryder.com/helicopter/t...?highlight=821
As for the Gyro,
I would recommend the Spartan and a JR DS8900G. I use this setup on my 700 and it work flawlessly. On my 600N I use a Curtis Youngblood Solid G gyro with a JR DS8900G. While the Solid G works very well, my personal preference is for the Spartan. You might also want to check out the Logictech 6100T gyro with the 6100G servo. I have been using one of these combos on my 600 electric for over a year with excellent results. The Logictech takes a little more time to setup properly, but once done holds and performs as well as many of the other high end gyros on the market. The best part about the Logictech combo is you can get it for $200. http://www.heliproz.com/prodinfo.asp?number=138370
I have never used one of the Align gyros, so I can't comment on their performance.
ORIGINAL: basman
ORIGINAL: basman
ORIGINAL: basman
I personally use a Hobbico Torque Master 180 starter powered by a 4S lipo to start both my 600 and 700 helis. I fabbed up a little mounting plate for the lipo and now the starter is very portable and easy to use. This thing packs plenty of punch and does not even break a sweat when turning over my 90. http://www3.towerhobbies.com/cgi-bin...?&I=LXL398&P=7 I am also just using the cheap Century starter wand without any issues at all.
http://www.readyheli.com/HEX_START_W...G_p/cn0427.htm
Here is a quick pic of my starter.
Hope this helps. Good luck with your new 600.
IN
RE: Trex 600 gyro ?
I have a 600nitro pro that I bought 2 years ago and I went overboard on the gyro/servo. Bought the 611 with a 9256. I just won a Hirobo SDX at IRCHA and I'm going with a Spartan and and Align DS620. ReadyHeli has the Spartans for $170 and the DS620 for $68. Alan
My Feedback: (8)
RE: Trex 600 gyro ?
Here is the latest and greatest from Futaba. Even smaller than the Spartan gyro.
http://www3.towerhobbies.com/cgi-bin...&I=LXVND7&P=SM
IN
RE: Trex 600 gyro ?
Yea, I would have gone with the gy520 if the Spartan was still the same price but like I said, ReadyHeli dropped the price on the Spartan to $170. Alan
CA
RE: Trex 600 gyro ?
The gy520 is a great gyro as well. I fly with a guy that has one on his TRex 700. He prefers the performance and size of the GY520 over the GY611 that he is using on his TRex 600. There are tons of really good gyros out on the market right now that greatly outperform the old GY401. I don't think you can go wrong with any of the ones mentioned in this thread.
NJ
RE: Trex 600 gyro ?
What about the GY520? You guys think that's better than the Spartan DS760? Only reason I ask is because I know nothing about the Spartan's and I've read nothing but good things about the 520. Are any of you guys running the 520 and can tell me first hand what you think?
IN
RE: Trex 600 gyro ?
The Spartan was the "had to have' gyro until the gy520 came out. Personally, I don't know if one is really better than the other. I think it might boil down to ease of setup and programability. I just bought my first Spartan and have not installed it yet so I can't tell you how easy or hard it is to set up. I have always used gy401's and a the 611 and I'm comfortable with them. Alan
MI
RE: Trex 600 gyro ?
If you follow the Finless video on Spartan setup (don't bind at left stick, it's no longer required, bind at center rudder), it's a piece of cake.
Scott
Scott
RE: Trex 600 gyro ?
OK 1st up cheers for the heads up. Ened up with the following GP 750 with a Align ds 620 $ 187.84 US. Cylic servos going with the Align ds 610 $ 152.98 US. The fact the ds821 Soectrums where no good kerbed the budget other wise the spartan would of been the choice. No 3d stuff for this black duck yet, so set up should surfice for quite a while
I did grab one of those Align starters so will give you the heads up once it's up and running. Received the Trex last friday, man there are some parts, I don't think there are two things bolted together. At least I will know, that all is lock tite. I haven't seen the 600 pro with a white cannopy before, I have questioned the seller I was under the inpression it was going to be yellow.
MI
RE: Trex 600 gyro ?
ORIGINAL: basman
Scott
IN
RE: Trex 600 gyro ?
You'll really only need the blue locktite. I have a 600nitro Pro and there is nothing in the assembly that needs the permanent stuff. As for the metal to plastic parts, everything I have read says NOT to use any kind of locktite on plastic as it causes a chemical reaction and makes the plastic brittle. The instructions recommend CA as threadlock on the metal parts that go into plastic which is only the balls into the control arms, etc. Bearings get Shoe Goo to keep them from spinning in the races. By the way, the kit comes with a small bottle of R43 and R48 locktite. The R43 is the same as blue or medium strength and the R48 is the permanent stuff. I suggest going over to HeliFreak and watching the Finless build vids for the 600n. Everything you need to know is in those vids. I built mine just from the vids, really never used the manual except for parts reference. Alan
RE: Trex 600 gyro ?
Cheers to all for the info, the Finless vid's are awesome. I am half way through the build and loving it. The align starter turned up, as always looks to be good stuff, will let you know when we krank the os 50 over. Have ordered an adapter for plane props, so we can give this thing a run for it money. ........ Brian
TX
RE: Trex 600 gyro ?
If you haven't bought one already...the gy401 is a great servo...you can find them used for about 80 bucks shipped...around 120 with the 9254 servo... Just a thought
the other servos are great...but are you good enough to see the difference?
RE: Trex 600 gyro ?
Ok this w end building. Nothing else on the cards so heres whats going in the beast : align RCE-B6T 2in1 voltage reg and ignition
: align 18c 7.4 1900mah Lipo power supply
: align RCE-G600 governor
All above came with the combo package
: Align GP 750 gyro and DS 620 servo
: Align DS 610 servo x 3 collective servo's
: Hitec HS-422 to throlte
The sparton gyro would of been the choice, but having to buy collective servo's which was unexpected expense blew the budget on that one.
I am also upgrading the screws with one of these kits http://www.rcbits.com.au/content/rcs...less-screw-kit
One of the guys at the club put me on to them. Probally not as much a problem of stripping screw heads on the 600 but I am also have a replacement kit for my 450 pro. Have had problems with stripping heads when working on it so while I am building and at a cost of only $ 36.95 AU seems a good option.
