401 set up ?
I have a Trex se with a Futaba 401 and 9650 setup. My ? is how can you make the stick more sensitive on the tail ? I have a 8103 set at 100% on end points the gyro limiter is set at 60. That gives me full travel in both directions a rock solid tail, but I would like the stick to be a little faster. It's almost like using dual rate but I"m not. Any help would be nice and Thanks in advance.
RE: 401 set up ?
Found my answer at anouther site. Thanks
| All times are GMT -8. The time now is 09:17 PM. |
