RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Align 35 esc? (https://www.rcuniverse.com/forum/t-rex-heli-435/5329308-align-35-esc.html)
fishbowl 01-27-2007 12:34 AM
Align 35 esc?
I can not get the first setting set (brake) I would like it to be soft brake? I can set all of the other ones i leave the stick in the middle for 2 on all . when i go to check, only one beep then the rest 2 . i can change all just not the first one(brake) what am i doin wrong????????? any one have a prob with this??????????
Im sure im doin somthin wrong just not sure what
Thanks for any help
BarracudaHockey 01-27-2007 08:08 AM
RE: Align 35 esc?
You probably are using a Futaba radio, reverse the throttle channel. You DEFINATELY want NO BRAKE.
fishbowl 01-27-2007 10:08 AM
RE: Align 35 esc?
I have a DX7 ........and i think i have it set up ........ first 1 beep no brake, then 2 beeps and so on.
I still cant seem to change the first one if i wanted to though , 2 thur 5 i can set ,no prob. Its just the first one.
So the ? is now.......Is it broke that it dont change ?
Dynamic 01-28-2007 02:03 AM
RE: Align 35 esc?
Make sure that your throttle curve is linear (a straight line from lower right to upper left) or it wont detect your inputs correctly.
