RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Trex problem (https://www.rcuniverse.com/forum/t-rex-heli-435/5969318-trex-problem.html)
fxlrcbkr 06-10-2007 03:17 PM
Trex problem
HELP
Newbie to this helicopter thing and in trouble allready. Broke my heli and havnt even finished buildiing it. Bought a T-Rex 450S (CF) and when trying to install the flybar assy found that the flybar control arms would not fit flush up against the hubb. Measured the flybar control rods and they are the correct length. Seems this gap would allow the flybar to slide back and forth in the hubb in flight causing a vibration. Thanks
whtmex 06-10-2007 08:48 PM
RE: Trex problem
If you have the plastic head assembly, you have to put some pressure on the flybar cage to make it seat flush against the seesaw.
ptb 06-10-2007 09:30 PM
RE: Trex problem
:)Some people use washer's to shim it , I just squezed it and tightened the screw's !!
fxlrcbkr 06-11-2007 07:01 AM
RE: Trex problem
Thanks for the help guys.
