450seV2 flybar lengh
my Trex 450 seV2 came with 220mm flybar rod, it was damaged and had a replacement sent but its lengh is 190mm. is this ok and why is new flybar 220mm
RE: 450seV2 flybar lengh
190mm is fine and you probably wont notice the difference unless you are flying insane 3d.
they upgraded to 220 "supposedly" to make it more stable and increase/maintain cyclic rate under constant thrashing. arguments have been made that shorter flybar is better for 3d, but i think the longer flybar is better. |
i find the 220mm flybars better in flight... more stable although responds fast too... the 250mm are far better...
