TIGHT BLADE
One of my carbon fibre blades on Trex450seV2 is very tight in the grip which wen the heli is spooled up wobbles cos it cant straighten up. It must be thicker than the other blade which is ok in the grips. Can it be sandpapered down a little to fit
RE: TIGHT BLADE
yes....
it is common for blades like the 325 pro woodies to be a bit thick at the grip.... sand carefully, rebalance, fly |
