RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Glitches??? (https://www.rcuniverse.com/forum/t-rex-heli-435/6939660-glitches.html)
rcflyerdave 01-20-2008 03:55 PM
Glitches???
How do I get rid of glitches??Ive tried 2 receivers and wd40 on belt. What is the best receiver? Diamond advertizes receivers that lock to Tx.Any good? What is the good setups??I dont have 2.4 setup.I have 9CAny help appreciated.Almost finished my 3rd rebuild.
Dave
dooleyje 01-20-2008 04:31 PM
RE: Glitches???
The Futaba 146i PCM is popular. H-tek Electron and Neutron dual conversions are also popular as are the 2.4 offerings. I use a Berg7 PPM with my 9c with a Revolution whip antenna. no gliches so far. You do need a ferret ring on the lead coming from the ESC before the receiver. Align makes a pack of 3 for a couple of bucks. I also have a Corona 8 dual converstion I heard was pretty good. I haven't used it yet. Has any one used the Coronas before? The receivers you are talking about are not in my radar so I could not tell you about it. Make sure you electronic and Antenna are as far from your Motor. ESC as possible. Do not wrap the antenna around the skids. In my set up the receiver is as far back in the back as it will go. The gyro is mounted under the Boom and the tail servo 9257 is on the boom. The Esc is way up in front of the motor on the botton tray and the battery in the top tray. With the FP 2170 EVO 25 11.1 packs that I use, it balances just right.
Jim
rockhouse 01-20-2008 07:10 PM
RE: Glitches???
Tried everything. Only thing that worked was going to the Spektrum DX7. Absolutely no problems since.
