RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Setup curve's for beginner using Optic 6 (https://www.rcuniverse.com/forum/t-rex-heli-435/8576307-setup-curves-beginner-using-optic-6-a.html)
joe1 03-14-2009 03:13 AM
I have been flying a Honeybee FP Modified, and I flew a friends E-Flight CP Pro with a HH Gyro and did real good, so I bought a Trex-450 .
I have a HiTech Optic 6 TX and I would appreciate anyone who is using this TX if they could give me the throttle curve's and pitch curve's for a beginner setup that is only wanting to fly scale, I'm to old for 3-D but I did manage too fly some 3-D on my RealFlight G2 Sim ( Ha-Ha ) .
Thanks To Everyone
joe1
au_wozza 03-21-2009 10:10 PM
RE: Setup curve's for beginner using Optic 6
Hi
I used the setup here to start off with(basically the same as in the T-rex manual) http://www.trextuning.com/setuptrex.php
then tweak to suit,for example if heli bobs up and down(yo yo effect) when your up out of prop wash (3 to 4ft up) then raise the pitch curve slightly.
if the tail bobs up and down or heli feels to mushy raise the throttle curve a bit.Start of with no expo,If you find your consistently over correcting then add about 5% expo for aileron and elevator at a time till ya happy,add about 15 to 20 % expo on the rudder this will help keep the tail still due to thumb/hand shake's on the stick in the early hovers :)
Cheers
Wozza
joe1 03-22-2009 01:33 AM
Hi au wozza :=}
I will try those settings to start out on and go from there, I did not get no instruction book with mine, and being I'm new to the CP heli's I don't want to fry my ESC & Lipo's because I had to much pitch and not enough throttle, so I really appreciate you replying and giving these starting settings.
Thank You
joe1
au_wozza 03-22-2009 02:11 AM
Hi Joe
Not sure what ver of the T-rex-450 you have but here is a link to the SE ver manual in pdf format
http://www.horizonhobby.com/ProdInfo...0SE_Manual.pdf
(Right click on the link and save target or save link as)
Cheers
Wozza
