RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   difference between belted and geared helis (https://www.rcuniverse.com/forum/t-rex-heli-435/8976619-difference-between-belted-geared-helis.html)
Jone951 07-30-2009 01:31 PM
im deciding between the genesis 450 v2 and the v2 blueray 450 and i dont know the pros and cons of the belted system and the the geard system. also what heli would you recommend between the 2? thanks
BarracudaHockey 07-30-2009 03:56 PM
RE: difference between belted and geared helis
The torque tube drives use less power and doesn't require periodic adjustment. Its a little harder to set up to get the gear mesh correct but once you're done your done.
Belt drives are more forgiving. Bump the tail on a torque tube and you're replacing gears, crash and your replacing the drive along with the usual crash parts where belts rarely break in a crash.
For a beginner, get the belt drive.
KCinNC 08-01-2009 09:10 PM
nothing wrong the the belt drive....just keep an inspection on teeth wear & tension
noobflyer01 08-01-2009 10:13 PM
ORIGINAL: Jone951
I'm not sure if you know this already but none of the models you listed above is a torque tube setup. the genesis and the blueray bothhave belt drives. The trex450 PRO is a torque tube setup. between the blueray and the genesis I'd get the blueray.
Fly To Chill 08-01-2009 10:52 PM
+1 for the blueray
