RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Does this sound right ? (https://www.rcuniverse.com/forum/t-rex-heli-435/9381787-does-sound-right.html)
dtacmed 01-02-2010 11:31 PM
I have a 6ex Futaba Radio. My throttle is set at 0,50,60,75,100 my Pitch is set at 0 at zero, 5+ mid stick and +11 at full stick this in Normal I don't fly 3D. My issues is my pitch settings on the radio are( 1 = 0 ) (2=10%) ( 3= 15% ) (4 = 20%) and (5 = 25%). However my pitch settings are right. Just wondering why my pitch # on my radio seem so weird.
Cleared2Engage 01-03-2010 12:33 AM
RE: Does this sound right ?
Those are really weird numbers. Go back and take a look at your linkages. Your pitch linkages may be too far out or in. Verify that everything is mechanically zeroed out. Do you have a swash plate leveler? Also verify your mixing arms and washout arms are level when you are at 0 degrees of pitch.
dtacmed 01-03-2010 07:23 AM
Everything was set up by the book. I have a 600 with pitch numbers pretty close to these. everything is level at 0 pitch. They actually fly fine was just wondering why these numbers were this low even though based on stick position pitch is right.
Cleared2Engage 01-03-2010 09:31 AM
That is pretty strange.
A. J. Clark 01-03-2010 10:28 AM
Should have your minumun pitch (0%) at the lowest stick position ( say -10 degrees).
Zero pitch (50%) at mid stick position and maximum (100%) positive (say +10 degrees)
at the highest stick position. Then adjust the percentages in the pitch curve of the radio
to what you want to fly with.
Ybenjulkay2x 01-03-2010 04:13 PM
are those numbers are from the radio LED or from the pitch gauge. It puzzle me , from the pitch gauge suppose to be at least +10 at highest stick position; 0 at mid stick; -10 at lowest stick.
Rafael23cc 01-03-2010 04:39 PM
Guys:
Although it does seem strange, you all need to read his message again. Stop suggesting that his pitch curve needs to go from -10 to +10. He set it up that way because he does not fly 3D. And he says he set it up by the book.
dtacmed
Here is my take on it:
I think you used a mix of a 3D set-up (long servo arms and 3D settings on the head) that is the reason for your reduced pitch curve numbers.
Since the 600 is capable of going from at least -10 to +10 then it seems that pitch settings that go from 0 to +10 should correspond to a pitch curve of 0 to 50. on "normal" (3D) settings. With a shorter servo arm, and different settings on your mixing arms, you should be able to bring that pitch curve to 0 to 100 and keep your pitch settings of 0 to +10.
But then, are you sure you will never go for 3D? I learned the hard way that you should learn now to fly with a 3D pitch curve instead of trying to change later.
Rafael
dtacmed 01-03-2010 10:06 PM
No0w its starting to make a little sense. I did set it up as if It was going to be 3 d capable at least as far as servo arms and throws. Obviously but not going negative I don't need the throw needed for 3D. Do you think I need to shorten these arms or just deal with the numbers as is?
Rafael23cc 01-03-2010 10:20 PM
ORIGINAL: dtacmed
Well, It depends on what you want to do. If you really want to keep the non-3D set-up, you should shorten the arms, and re-adjust the linkages. I do recommend that you program some negative on your set-up at least -4 degrees. You WILL thank me the day that a gust of wind catches you off guard. Start at -4 a 0% on the pitch curve, then program about 5 to 6 degrees at 50% and finally 10 degrees at 100%. This will take advantage of the full resolution of your radio. Also make sure that your servo travel is set to 100%.
Rafael
dtacmed 01-04-2010 06:00 AM
Thanks I set it up that way i did notice in the wind the other day I need neg pitch on landing. Not as big of a problem with the 600 but with the 250 it was=. Thanks for the response.
dtacmed 01-06-2010 08:21 AM
I was going to shorten the servo arms as mentioned above however with the Align servos moving in the balls looked as if they might bind. I did re-adjust everything and dropped all the servo arms down 1 spline. Now my pitch settings run from 0 - 50 %. Getting closer. As stated earlier I'm set up for normal scale flight only with low stick now being -2 @ 0% and high stick being +11 @ 48% I guess these numbers sound a little more "normal"
