Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Evolution 46nx
Old 02-14-2014, 10:50 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Globee tachometers are not real reliable. Blubbery rich on a 9x8 should put you closer to 14k if even that.
Old 02-15-2014, 07:09 PM
SIKrandall
I dont know man. I seen an o.s. 46fx turn 15,700 with a 9x8 on a jett muffler. You think I should only be at 14,000? Im not sure your giving the little evolution enough credit.
Old 02-15-2014, 07:39 PM
1QwkSport2.5r
In your words, "it was pretty blubbery rich and quit before I got it into a semi smooth 2-stroke". That tells me you didn't have it peaked for one, and for two GloBee tach's are known for being inaccurate. It's not that I don't believe you, I don't trust your tach is telling you the whole truth. That's all. Nothing personal. For two, an OS is not a benchmark I would consider comparing against. Your Evolution should walk all over an FX. A semi smooth 2-stroke for my TT is around 13,500-14,000 on a 9x7 and Jettstream. Peaked on a 9x7 I last saw 16,700rpm on 10% homebrew. Your Evo should have a bit more power than my TT. It's not likely to pick up or lose 1000rpm or more by going up or down 1" of pitch.
You don't hang out with Airraptor do you?
Old 02-15-2014, 08:30 PM
SIKrandall
Lol no. I recently chatted with him about some of his motor stuff though. Thinking about sending him a tt pro 46 to experiment around and see if its a good deal or not he does. I didnt get a chance to run the evo today......hopefully tomorrow ill get some good info on a few different tachs. The other day it started out blubbery rich.....I leaned it down quite a bit but it was definitely not peaked.
Old 02-16-2014, 04:00 AM
1QwkSport2.5r
He is not all he is cracked up to be. His claims are pretty big, his "engine guy" does some pretty crude dremel work. Don't expect a race engine type performance from his mods.
Old 02-16-2014, 07:23 AM
  #31
SIKrandall
I've done work over the years on big 2 strokes in dirtbikes and what not. Haven't cracked into and rc engine yet but all the principles remain the same. I need to pick up a little degree wheel and go to town. Im a little nervous about digging into some engines though. Anything with a nickel cylinder sounds like a time bomb.
Old 02-16-2014, 07:46 AM
  #32
1QwkSport2.5r
The trick with nickel is diamond files. After grinding the ports, the plating on the inside needs to be ever so slightly beveled with the finest file you can find so the piston doesn't catch it. If that makes sense.
Old 02-16-2014, 08:34 AM
  #33
SIKrandall
It makes perfect sense. Its the exact same with a nikasil cylinder on a motorcycle. The problem is its on a much smaller scale. Gonna have to get small enough tooling to not demolish the cylinder.
Old 02-16-2014, 10:30 AM
  #34
SIKrandall
Ok so I got some time to run the evo in today. Peaked on three tachs right around 16,350-400. Richened it back off to a steady 16,000 with the 9x8. Ready to get it in a plane and try it out.
Old 02-16-2014, 11:27 AM
  #35
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
That is quite impressive. I would not have thought the Evo capable of that.
Old 02-16-2014, 06:02 PM
  #36
oil_can_harry
I have a 46nt in my twist 40 running the 12 3/4 x 3.75 prop. Turning a little less than 13,000, with 15% but extremely responsive. Prop works like an air brake when throttled down to idle. Makes my twist just float in when landing. The twist doesn't need speed anyway so it's a good combo.
Old 02-16-2014, 06:49 PM
  #37
SIKrandall
I honestly didnt think it would do 16,000 either. Im kind of at a loss of words with it. Evo's seem to respond well to small diameter props. Its not the heaviest motor I've ever seen either. Im impressed for the price.
Old 02-16-2014, 09:34 PM
  #38
oil_can_harry
The Evo motor is the easiest to start of all the motors I have. They are easy to adjust and have a good midrange. I have started using the 52. It will wind tighter than the 46. I am swinging a 11 x 7 prop with a Jett muffler on a 52 in my L A Racer. Haven't checked Rpm's but it screams. I think I have 15 or more of the Evo motors. Have a 61 in a twist 60 swinging a 14 x 4 sport prop. It does excellent also.
Old 02-28-2014, 09:57 AM
  #39
SIKrandall
The stars must have been aligned just absolutely perfect the day I tested it. I am not seeing 16,300 anymore. Peaks just under 16,000 with the 9x8 and stays comfortably rich around 15,600-700.
Old 02-28-2014, 08:12 PM
  #40
speedracerntrixie
My Feedback: (29)
I would expect that drop off with the weather conditions we have been having the past few days. Warmer weather means more power. My race times will drop 5 to 7 seconds between morning and afternoon.
Old 02-28-2014, 10:06 PM
  #41
SIKrandall
I suppose that makes sense. However, humidity is the big one. Colder air isnt so much the issue as the humidity. Typically the colder the intake air is going into a motor the more power it makes. Hence a turbocharged engine having an intercooler or aftermarket cold air intakes sold for your car, but the wet crappy rainy weather isnt helping build power I dont think.
