Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Thrust HP or???
Old 12-21-2003 | 10:47 AM
av8tor1977's Avatar
Default Thrust HP or???
Hi,
Does anyone know of a program for determining thrust other than Thrust HP? Hopefully one a little more accurate??
I had another program before my computer crashed, but I didn't get to use it before my computer crashed, and now I can't find it again on the net.
Any help will be appreciated.
Thanks and Happy Holidays,
AV8TOR
Old 12-23-2003 | 05:36 AM
Pelle Gris's Avatar
Default RE: Thrust HP or???
Hi...
Try to find a program called "AeroDesign Propeller Selector"... That´s what I use, and it seems to be fairly accurate.
As far as I remember it was only off by a few pounds when I measured my G-62.
Old 12-23-2003 | 06:54 AM
My Feedback: (16)
Do you have a link to this program?
ORIGINAL: Pelle Gris
Hi...
Old 12-23-2003 | 12:20 PM
Pelle Gris's Avatar
Nope... can´t remember where I found it... But try a Google search... Maybe it will show up......
Hey...I found it.. Here you go.
http://www.gylesaero.com/freeware/propcalc.shtml
Old 01-03-2004 | 09:23 PM
av8tor1977's Avatar
Hey, thanks a lot! I downloaded it, and it is the same one I had lost.
Take care,
AV8TOR
Old 01-04-2004 | 11:34 AM
My Feedback: (16)
THis program looks good!
I will do some checks against thrust HP and see what happens.
Old 01-05-2004 | 07:49 AM
Scoubidou's Avatar
My Feedback: (17)
Hi
That propcalc seems to be more realistic than the very optimist TrustHP!![8D]
I have a small gasser MVVS1.6 turning an APC 17x10 at 7400RPM.
From ThrustHP: 13.72 lbs thrust
Propcalc:13.15 lbs thrust (with 10mph airspeed)
MA 18x8 at 7000RPM.
From ThrustHP: 14.5 lbs thrust
Propcalc:12.17 lbs thrust (with 10mph airspeed)
What's the relation between the airspeed and thrust? Is there someone who knows what does 'airspeed' mean in the first case?
Scoubi
