YS 1.10FZ Tach readings
My Feedback: (15)
FL
RE: YS 1.10FZ Tach readings
ORIGINAL: jose_ribeiro
Sean, is the ys110 more powerfull than the saito 150? (without mufler)
Thaks very much.
Jose Roberto Ribeiro
Thaks very much.
MI
I think on 20/20 fuel, Saito 150 should not be weaker than YS 110. On 30% heli fuel, I think YS 110 will start to pull away. Also, YS 110 is lighter, so that's the definite advantage. It's also cheaper too.
#31
LA
I AM PUTTING MY YS 110 ON A SEAGULL 260 I HAD IT ON A FUNTANA 90 IT HAD ALL THE POWER YOU NEEDED TO TEAR THE WINGS OF IF YOU DID NOT WATCH IT I ALWAYS RUN 30% HELI FUEL COOL POWER
#32
YS 110-S
10100 rpm on Youngblood 30% heli fuel, exhaust baffel removed and Evolution 16x6 prop with a 2.5"spinner.
This combo measured 16lbs 8oz of thrust with a digital fish gauge, I am going to try a APC 16x4W next.
That is around 2.6 - 2.8 horsepower...
#33
So I tried a APC 16x4W and it spun 10,800 but only produced 16lbs 10oz or 2 ounces more than the 16x6.
So the 16x4W is very inefficent and 10mph slower than the 16x6.
The bottom line is the YS 110-S rocks
#34
ORIGINAL: tIANci
Okay ... after about a gallong my YS110 is really performing, here are the new figures:
YS110
Fuel: 30% Cool Power (heli)
Prop: APC 16x6
NO muffler
Peak: 10,300 RPM
YS110
Prop: APC 16x6
WITH muffler
Peak: 10,000 RPM
I run it at 9,750 RPM. I find that the engine performance is lousy if it is peaking at 9,300-9,500 on the ground. YS support forum recommends running at 10,000 RPM and I see some truth in it. My engine is running at only about 210F-220F after flying her semi hard, not too hard. Hence, the engine temp is very good.
Tomorrow I will be trying out the APC 17x6, shall give you all the figures.
Build - I am not buying any more Saitos ... YS may cost more but its worth every dime!!! I ordered a YS160 after this one. Saw a YS63 perform too ... sweet as heck. YS engines are the way to go. My TT120 2C gives about the same max RPM as the YS110!
YS110
Prop: APC 16x6
NO muffler
Peak: 10,300 RPM
YS110
Prop: APC 16x6
WITH muffler
Peak: 10,000 RPM
Nice thread, has lots of data for new YS110 owners. Are you still running this engine without the exhaust baffle? Though you are getting more RPM, I wonder how the lower back pressure affects the engine? Obviously there will be a bit more wear and tear running higher RPM but don't think it will be that critical regarding the life span of the engine.
Is yours running reliable?
Thanks.
#41
BC, CANADA
(FWIW)I have a YS120sc and it appears The 120 still has a bit of extra oomph over the Newer 1.10s I'm getting 9000 rpm from a Ma 18-6 wide classic on 30 % 7500 with an 18-8 wood prop.Your 110s get the weight advantage tho. I'm waiting for the new 1.15 to come out .Sounds perfect for my upcoming Kyosho Kelly
#42
ORIGINAL: BartekSz
Is it possible to achieved substained idle on 10% nitro fuel and 18% oil?
No problem, I have flow my YS 110 many flights on 0% (straight) fuel just to try it. Once tuned/adjusted for the fuel it ran fine, although less power of course. Both me and a friend feed our YS`s 15/15 fuel for the most part and they run great. I guess 10% nitro will be no different. To get the most out of it (if you need it) 30/20 fuel is the best
