Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Tachometer Readings
Reload this Page >
O.S 1.60FX Owners. Post your tach readings
Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Old 10-16-2010, 10:44 PM
  #426
Super08
Super08's Avatar
Default RE: O.S 1.60FX Owners. Post your tach readings
I was having problems with my engine when I first used the Bisson pitts as well. If you go back in this thread you will see it. I solved the problem by mixing up JB weld and filling in the exhaust pipes about 1 inch or so. I had a pen stuck into the JB weld and then drilled out the plastic after the JB hardened. It restricted the exhaust just enough to increase the pressure in the tank to take away the detonation at low to mid throttle and also made it easy to tune. I had no effect on top end rpm. This was the new style Bisson Pitts with the rounded down tips btw.
Old 11-12-2010, 01:49 PM
  #427
hornetnz
Can anyone point me in the direction of a pitts style smoke muffler that will fit on the 160?
