Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Quadra 35 on tuned pipe.
Old 07-22-2006, 07:23 AM
Pelle Gris
Pelle Gris's Avatar
Default Quadra 35 on tuned pipe.
MenzS 20x8: about 7000rpm, but the plane didn´t fly very well with that prop.
APC 20x8: 8000rpm, transformed the model completely. No need for another engine now..:-)
APC 18x10: about 8000rpm too, but measured on another tach so I can´t be sure of this number. Did pull very well it seemed.
Old 07-28-2006, 03:30 AM
the Wasp
Default RE: Quadra 35 on tuned pipe.
""APC 20x8: 8000rpm, transformed the model completely""
was that the wide blade prop or the narrow blade prop ??
Jim
Old 07-28-2006, 05:05 AM
Pelle Gris
Pelle Gris's Avatar
Hi Jim
I think it´s the "normal" style. As far as I remember it says C-3 on the hub.
Old 07-28-2006, 08:21 PM
the Wasp
""C-3""
well I know W is for wide and N is for narrow, I don't know what the C is for,,
thanks anyway's !!
Jim
Old 12-26-2006, 06:35 PM
thisoneused
My Feedback: (-1)
What is the weight of this plane?? And how would you describe it's vertical performance?
Jim
