Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Magnum 61 fs
Old 12-17-2006, 08:23 PM
chashint
Default Magnum 61 fs
On 10/07/2006 my brother and I recorded these numbers.
Engine: Magnum 61 FS
Fuel: Morgan 15% all synthetic
3 blade prop: Master Airscrew 10x7, 10600rpm (sustained, not peak), 4lb 12oz static thrust
2 blade prop: Master Airscrew 12x6 Scimitar, 10000rpm (sustained, not peak), 5lb 5oz static thrust
