Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Magnum 52 RFS tach reading
Old 04-08-2003, 03:09 AM
SYBERSTU
Default Magnum 52 RFS tach reading
Magnum 52 rfs APC 12x6: 8900 to 9200 running slightly rich. Engine is somewhat new, about 1/2 to 3/4 tank run through at 1/2 to 3/4 throttle. (Installed on Global Blue Max). Idle is okay at 2900 to 3000 but will fall off under 2900. Do I need more break in and is the power in line with other Magnums
Old 04-25-2003, 03:51 AM
CGAV8R
CGAV8R's Avatar
I get 10,000 on a 11x7 top flight power point
9000 on a 12x6 top flight power point
Old 05-13-2003, 01:15 AM
RCAddiction
My Feedback: (87)
RCAddiction's Avatar
Default Magnum 52
15% Wildcat
10,500 on 12x6 MA (nylon)
10,500 on 11x8 MA (nylon)
This is a 1999 production model with the longer, thinner muffler., shaped like the OS52 muffler. The factory switched to a shorter, fatter muffler about 2 years ago or so, which hurt performance, but was quieter. They have since re-launched a longer thinner one that is quieter and but also has the higher performance as well.
Old 07-22-2006, 07:09 PM
Stubshaft
Default RE: Magnum 52 RFS tach reading
Getting 9800 on a 12x5 APC
15% Coolpower
Old 10-21-2006, 03:28 PM
skiman762
skiman762's Avatar
apc 13x4 sport 9800 on 15%
