Irvine 39
RE: Irvine 39
Just tried an APC 10.5 x 4.5 using S&P 15% nitro fuel and got 14,760 rpm. Really nice, steady howl. It's a relatively narrow blade so that must affect it, but it was still more than I expected. Lots of power for my World Models LA 40 Racer!
Jim
Jim
RE: Irvine 39
Mine is the UK one.
Go to the diesel forum if you haven't already. It's got a big carb and a lot of porting.
Jim
Oh, I just realized, you know diesels very well as I recall.
Jim
bad luck , this new motor has an bad bearing on the cranckshaft at the backsite. The statical rpm does not exceed 11000 rpm.
The bearing was damaged very bad, metal part came in the liner, it has stripes now. The bearing is underdimensioned (13*42). It is replaced by Rob Metkemeier with a 2,5 cc teamrace motor.
For the Irvine .39 I would not recommend high rpm applications. 3D Funfly with less than 13000 rpm fits this Engine better.
#33
I added a picture of the Irvine .39 rear bearing (right side) together with a 61902 bearing which is used for normal 40-sized engines from almost all manufacturers (ST G40, OS 46FX, 50SX, China, Taiwan...)
We pay the price for a super lightweight and powerful engine by extra stress on tiny components.
@buzzard bait
You can run the engine as you like but from the experiences we share here you are aware of this problem and you may have extra attention to symptoms that come from the bearings.
If there is bearing noise or roughness I always check the bearings in my engines. Operating them with this symptoms may lead to more damage than just pitting on the bearing surfaces.
#35
Why is it so IDIOTIC to register for this site ??? Email is NOT required for registration, no red asterisk. But when you press the button, it won't allow you to register unless you give an email ??? Needs checking out.
Also, when you browse, then log in, there is la ink to go back to the page you were browsing. But when you browse then register, no such link. Why would that minor bit of inconvenience be there ???
#36
I had an Irvine 39 many years ago. I recently acquired another. The compression didn't feel "quite right", it was good, but not the way I remembered it. So I bought Just Engines' LAST Irvine 39 piston and liner, fitted it, and ran the engine in *.
I now have it in a Limbo Dancer 3D (I've added SFGs etc to a standard LD). I started off with a 12,25 X 3,75 APC, that really killed it ! Then I tried an 11 X 4 APC, better...but now I've got a 10 X 4 APC and I get 14,400 RPM. Sounds right too. I'm using Model Technics Contest 10 fuel and standard pipe. I'm still sorting out the bottom end, and it
*may not be fully run in yet, only had 6 or 7 tanks through it.
It flies the LD well, bags of top speed, too much for a funfly! But it doesn't prop hang very well. When I hold the model vertical on full throttle and let go for a split second (do NOT try this at home), it goes up SLOWLY, but not a patch on my electric 3ds, or my High 5 (similar size to LD) with a West 52 T1 and Genesis pipe.
I'm thinking that while the Irvine 39 IS still a pocket rocket, and I love it, to get the kind of power to weght ratio to which I have now become accustomed, I either need a bigger engine or a smaller lighter model.
Any thoughts ? Suggestions ?
#38
I use mine on a Magic 3D Funflyer with the APC 12,25x3,75 and it seems the right prop for the engine in this application.
What do you exactly mean wit "really killed it"?
#39
A couple of points, I know that what I am expecting may be unreasonable: comparing it with my electric 3Ds (eg Lil' Banchee 3D by Cermark) weigh NOTHING, and a similar size funfly to the LD with the West 52, which is like a formula 1 engine ! These have an incredible P to W ratio, but that's what I've got used to.
I also read somewhere that these engines do take a LOT of running in, so maybe I must "chill" and be a bit patient.
All I know is that at this moment the Irv 39 does not give me the vertical performance I crave in a 3D model.
When you say "it seems right", what throttle setting does it hover at ? And if you then open the throttle fully, how quick does it accelerate vertically ? With my other models, I hover at most 1/4 throttle, and when I open up, it goes straight up, no lag, and unlimited vertical. Am I expecting too much from the Irv 39 ? Should I be more patient and run it in properly ? Thanks
#40
The vertical performance is very good. Hoovering at about 1/2 Throttle. The engine can be throttled like an electric motor. My exhaust system is a Stueckerjuergen 3D muffler for 50 sized engines but I think the maximum Output is about the same as the stock muffler.
Fuel: 20% Castor 5& Nitro.
With 10% Nitro it even turns the APC 13x4W without sputtering but the acceleration of the prop is too slow to go out of critical situations fast enough.
