Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Tachometer Readings
Reload this Page >
Evolution .60NX with Jett Stream Muffler
Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Old 11-25-2010, 12:58 PM
  #51
Dblex
My Feedback: (81)
Dblex's Avatar
Default RE: Evolution .60NX with Jett Stream Muffler
Yeah, u can blow through it.......
Old 11-25-2010, 01:41 PM
  #52
freakingfast
ORIGINAL: Dblex
I just cant figure this out...
my motor gets super hott and loads up
This is not loading up, it's starting to seize up.
ORIGINAL: Dblex
What are your guys needles at on the high end??????????????? Im curious!!!!!!!
What other guys are setting it at is not important, due the fuel the used,GLOW PLUG?? and needle manufacturing tolerances. You need to find your setting, apparently richer than what you're at now.
Old 11-25-2010, 01:47 PM
  #53
Dblex
My Feedback: (81)
Dblex's Avatar
She ran ok at 3 turns...so your probably right...
Old 11-25-2010, 01:51 PM
  #54
freakingfast
Fantastic!
Now have a Happy Thanks Giving!
Old 11-25-2010, 04:50 PM
  #55
jeff1951
Oops wrong post.
Old 11-25-2010, 05:00 PM
  #56
jeff1951
Do you still want my infrared temperature detector to check the head temperature?
