RCU Forums
-   Tachometer Readings (https://www.rcuniverse.com/forum/tachometer-readings-173/)
-   -   SF Meets AX (Pump & Pipe) (https://www.rcuniverse.com/forum/tachometer-readings-173/11557028-sf-meets-ax-pump-pipe.html)
rainedave 06-29-2013 06:36 PM
1 Attachment(s)
I've been away from these forums for a few years and it's good to be back. I'm glad to see some of the old names are still here.
Now on to business. I have an OS AX .55 that never ran well for me regardless of prop sizes.
By chance I found out that my SF .46-P pump carb fits the .55. This carb has a HUGE 9mm venturi. So, I tapped the back plate for a pressure nipple and hooked up the pump. I bolted on a tuned pipe header, too.
Soon, I will bench run this AX .55 with the SF .46 pump, pump carb and a tuned pipe. Let's hit 16K!
1QwkSport2.5r 06-29-2013 08:35 PM
RE: SF Meets AX (Pump & Pipe)
What prop are you trying to get to 16k?
rainedave 06-30-2013 01:20 AM
Well, it won't be with an 11x7. :)
I was sort of joking about the 16K, that would probably require a too-small prop like a 10x6.
1QwkSport2.5r 06-30-2013 08:07 AM
Good luck. I look forward to seeing your results. My ST G51 ran a little over 15k on an APC 10x6 with a .46 size Jettstream muffler bone stock. Curious to see how much stronger the 55AX is. Do post your results.
roncoleman 07-13-2013 01:04 PM
Dave!!
It's good to see you back. I look forward to seeing your results also.
Have fun.
Ron
countilaw 10-28-2013 03:50 PM
Whatever happened to the results?
1QwkSport2.5r 10-28-2013 07:05 PM
Wondered the same thing.
