3W-75i
With NX Wood Prop 26x10
Unleaded Gasoline 97, 1:50 break in oil. Rpm 5,720rpm |
RE: 3W-75i
HI RONY
MY 75I SWING MENZ ULTRA 26/10 UP TO 6400 AVGAS 1:50 CHECK SENSOR POINT |
RE: 3W-75i
ok thanks for information.
After break in period, at least can swing NX 26x10 at 6,000rpm( more than enough power for my H9 Extra 330 ) Rony |
RE: 3W-75i
All,
WH Giles 202 21lbs 3W-75I 26x10 3W wood , new - 6150 after 6 flights 6340 (have not touched the needles ) today : 26x10 Biela 5195 , idles 1150, pulls like crazy the burble went away at mid to low end still on 32:1 Penzoil. will change to 80:1 synthetic after two more gallons. Almost there. JDS |
RE: 3W-75i
All,
Update Switched from Pennzoil Air-cooled 32:1 to Red Line Synthetic at 40:1 also switched to 3W CF 26x12 two-blade prop. While noise has greatly increased with this propeller the climb and performance have also greatly increased over the Biela 26x10. Turns the 3W propeller at 6000 even. Doesn’t seem like it but this is a great 3D prop. JDS |
RE: 3W-75i
breakin in my 3w 75ius w/24x10 prop prozinger peak 6.900,and low idle @ 1.800 just run about 2 gallons of 92 octane w/32:1 lawnboy.
RE: 3W-75i
Dale,
It took over 7 gallons of 32:1 Penzoil Aircooled to get past break in on my 75I, tried to switch to Amzoil 80:1 at 4 gallons and the motor got hot so I switched back to penzoil. At 7 gallons I switch to Redline synthetic 40:1 and gained RPM and the motor runs just as cool as on penzoil (160-170 degrees F) No carbon build up, great response no saging at the end of the flight and no sewing machine sound on long uplines. The motor keeps getting stronger. Swinging a 3W 26x11 carbon at abou 6150 on the ground. She really unloads in the air. 3W 4-ever ! JDS |
RE: 3W-75i
THAT'S GREAT, ME ON THE OTHER HAND GOT A LITTLE TIRED OF HAULING THE WILD HARE BACK AND FORTH BIGGER PLANES ARE GREAT BUT NOT VERY CONVINIENT TO CARRY IN MY CAR.BUT I'LL GET RIGHT BACK ON IT REAL SOON,RIGHT NOW MY 3W IS ON IT'S 5'TH GALLON AND STARTING TO LOSSEN UP THE 24X10 ZINGER PROP. I HAVE ON IT NOW SEEM'S TO SLOW IT DOWN ON THE FINAL FOR MY LANDINGS,IT SEEM'S LIKE A JAKE BREAK ON MY EDGE 540T JAJAJA:D I HAVE TO GIVE IT A LITTLE GAS SO IT COULD REACH THE BEGINING OF ASSFAULT, THINK I'M GONNA TRY A BOLLY 23X10 OR 24X8 SOME PROP. WITH A THINNER BLADE.
RE: 3W-75i
Help please. I bought a 3w 75ius off rcu. I am having trouble getting it tuned right. it is turning around 5900 on the ground with a bolly 25x10 prop on 75 to 1 amsoil. It idles at 1900. It has a couple of problems. the transition is good on the gound but when i go to take off it sputters like it is going to die. luckly it doesn't. also at 1900 at idle the plane moves on ground quickly and i cant get it to slow down on landing. my needles are set at 3/4 on the high and 1 1/2 on the low. What do you think?
| All times are GMT -8. The time now is 07:37 AM. |
