RCU Forums
-   Tachometer Readings (https://www.rcuniverse.com/forum/tachometer-readings-173/)
-   -   thrust question (https://www.rcuniverse.com/forum/tachometer-readings-173/971382-thrust-question.html)
RCNutt-RCU 07-19-2003 12:00 AM
thrust question
Is there a simple formula for getting the amount of thrust if you know the prop diameter, pitch and RPM? RCNutt
w8ye 07-20-2003 04:34 PM
thrust question
Download this program and install it on your computer. You can compare two props also. It's rather commonly used by the people on RCU.
http://david_ironsides.tripod.com/i...craft/id15.html
Enjoy,
Jim
aquilajohn 08-28-2003 12:38 AM
thrust question
I just tried the link for thrust software and it did not work, says can't find. Did I do something wrong or should I just paste it in the address bar and try that way?
Graeme Marion 08-31-2003 06:05 AM
Greetings from Sunny Queensland
Hi Guys.
Try http://david_ironsides.tripod.com/.
Then click on Thrust Calculator in the index on the left hand side of the page.
Then click on the header Download Static Thrust Calculator .
Hope this helps. ;)
DarZeelon 08-31-2003 03:58 PM
Thrust...
RCNutt,
There is no formula.
The various thrust calculators, including those you are referred to by other posters in this thread, are all flawed. Some will give you the same thrust, for all props of a certain diameter, without any difference for different pitches.
With little confidence, you can trust some of them to tell you, which of two props will give you more thrust. But don't take the number as a biblical law, as it will by all likelihood, be very, very optimistic.
If you want the Reivers Prop Calculator that I use, send me an E-mail and I will send it back to you.
This calculator has been more accurate than others, in predicting the RPM I can spin a given prop with a given engine output.
