Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
tactic 650 flaperons
Old 11-25-2013, 05:20 AM
Default tactic 650 flaperons
Can you have flaperons on a tactic 650? I've been through the manual a few times and can't seem to find out how you do it. Maybe I've missed something??
Thanks, Dave
Old 11-25-2013, 07:56 AM
Bax
If you select the wing type of "2AI1FL", you can have the ailerons work with the flaps by using the Flap Mixer. If you only have two ailerons, but no flaps, select the same wing type and then use the Flap Mixer to make the ailerons work as flaps. You can make flaperons with pmixes, but you'll still wind up using the flap channel, so all six channels will be used up regardless. It's easier using the "2AI1FL" wimg type, since the mixer is built in.
Old 11-25-2013, 03:38 PM
Thanks Bax! I'll try it
Dave
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
