Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
Programing a Tactic 650 transmitter to a tactic TR1424 receiver
Old 10-23-2016, 11:23 AM
Default Programing a Tactic 650 transmitter to a tactic TR1424 receiver
Hello,
I want this setup to work as elevons but all controls on right stick mode 2
the Tactic tr1424 is a 4 channel Rx, ESC, servo combo board, with channel 2 being elevator and channel 4 being rudder
I can get the controls I want ok but pitch in on right stick and roll is on left stick
If you can help I would appreciate it
Thanks, Jerry
Old 10-24-2016, 06:18 AM
Bax
In the Model Setup Menu, you want to select the Wing Type function. In that function, select the "Tail Type" and change it to "Delta". That gives you the elevons you desire. That's described on page 16 of the instruction manual.
Old 10-24-2016, 08:09 PM
Bill,
I set tail type to delta and left stick controlled one servo and right stick controlled the other servo (each stick controlled one servo)
remember with the brick channel 2 is elevator and channel 4 is rudder
Jerry
Name:	Picture 002 brick.jpg
ID:	2187473   Click image for larger version
Old 10-25-2016, 06:46 AM
Bax
OK, reset the transmitter channel assignments. You cursor down to "Channel 4->Output 4" and change it so that it says, "Channel 1->Output 4".
The elevons will work with the tail type described above.
Old 10-25-2016, 01:57 PM
Bill,
Your getting me closer, all control is on the right stick now and the servos have the correct movement, but aileron stick moves control the elevators and elevator stick moves control the ailerons
Jerry
Old 10-26-2016, 06:57 AM
Bax
You will have to allocate the functions in the transmitter to the outputs that move the controls as desired. You may need to swap the functions.
Old 10-27-2016, 05:03 AM
Bill,
you said, You will have to allocate the functions in the transmitter to the outputs that move the controls as desired. You may need to swap the functions.
Could you Tell me how to do that
Thanks Jerry
Old 10-27-2016, 07:15 AM
Bax
You just reassign the channel outputs. If the elevator and aileron channels are not correct, you change them.
Change Channel 1 -> Ouput 4 to Channel 1->Output 1, and then Channel 2->Output 4.
Whatever it takes.
Old 10-28-2016, 05:55 AM
Bill,
I have tried all possible channel assignments without any luck, unless I can use the programmable options I`m beginning to believe it is not possible with this receiver brick
Jerry
Old 10-28-2016, 06:41 AM
Bax
A few posts up, you mentioned that you got the elevator and ailerons working of the right-hand stick, but they were swapped. Aileron stick movement moved the elevators, and elevator stick movement moved the ailerons. So you just need to set up that configuration again and then swap the way the channels did their output.
So if channel 1 went to output 4 and channel 2 went to output 2, you need to then set it up so that channel 2 goes to output 2 and channel 2 to output 4.
It really is that simple!
Old 10-29-2016, 03:13 AM
Bill,
What are we not communicating to each other, the brick says channel 2 is elevator and 4 is rudder, does not the tactic mix channels 1and 2
when setup as you have stated
(So if channel 1 went to output 4 and channel 2 went to output 2, you need to then set it up so that channel 2 goes to output 2 and channel 2 to output 4)
what I get is channel 1 (aileron) both servos move same direction as if they were the elevator and channel 2 (elevator) both servos move in the same direction as they should
Either their is something I`m not communicating to you, or its not quite as easy as we think
Jerry
Old 11-01-2016, 08:55 AM
Bax
I mis-typed my post above. Here is the relevant portion edited:
So if channel 1 went to output 4 and channel 2 went to output 2, you need to then set it up so that channel 1 goes to output 2 and channel 2 to output 4.
Old 11-02-2016, 04:26 AM
Bill,
I got it, and this is how:
Wing type Delta, as you said
TX channel 4 output 1
Servo reverse, channel 1 was normal, I reverse it
Then I swapped the servo arms, so what was controlling one side is now controlling the other, which was easily done if you look at picture 10 posts above
Thanks, for your help and you patience
Jerry
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
