Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
Aileron/rudder mix
Old 02-15-2017, 09:15 AM
Default Aileron/rudder mix
Beginner pilot.What aileron rudder mix should I go with a Sensei and tactic 850? any suggestions Thanks S.T.C.
Old 02-15-2017, 10:33 AM
Bax
What do you mean ".What aileron rudder mix" should be used? In the Setting Menu, you use the Aileron mixer, which is actually the aileron->rudder mixer. Since it's a built-in, you don't need to use a programmable mixer.
Old 02-15-2017, 10:55 AM
thanks bax
Old 02-15-2017, 11:13 AM
Bax on the settings menu Aileron/Rudder settings read+0 Do I leave it at Zero or change it and do I assign a switch? I am Bamboozeled and not with Booze .Just do not understand
Old 02-16-2017, 08:11 AM
Bax
You change the numbers so that you get the amount of mix needed. You assign a switch only if you want to turn the mix on or off at different times. If you want it on all the time, then don't assign a switch.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
