RCU Forums
-   Tactic & AnyLink Support Forum (https://www.rcuniverse.com/forum/tactic-anylink-support-forum-522/)
-   -   TR625 antennae position (https://www.rcuniverse.com/forum/tactic-anylink-support-forum-522/11601194-tr625-antennae-position.html)
time bandit 07-10-2014 01:57 AM
I have a carbon fiber wing rod that one of my antennae's will be close to. Will the carbon fiber rod affect the signal reception?
Bax 07-10-2014 06:15 AM
Carbon fiber is electrically conductive. Therefore, you want your receiver antennas as far away from any carbon as possible. If the receiver antennas are too close, the carbon rod can shadow the antenna in some flight orientations. With the two-antenna receiver, you want the two antennas as far apart from each other and at 90 degrees to each other. As with any receiver installation, the antennas should be as far from battery and servo wiring, any ignition wiring, battery packs, metal pushrods, carbon rods and tubes, and so forth. With carbon fuselages, the receiver antennas should go through the fuselage sides to be exposed outside.
time bandit 07-10-2014 01:42 PM
The TR625 came free with the radio in a special sale from Tower Hobbies. I was going to get the TR624 since I don't have a lot of room inside the fuse. I have the receiver in a Mountain Models EVA Sport which is a park flyer type airplane. There's no way that I can see to keep the antennae's totally away from the battery, CF rod, esc, servos etc. unless I have them exit the fuse as you suggested. Thanks for your time.
David Stewart
Bax 07-11-2014 06:23 AM
Mostly, you do the best you can and then do a thorough range check to make sure it's woring well.
