Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
urgent help needed - stampede
Old 06-25-2011, 03:33 PM
modeleryang
Default urgent help needed - stampede
Can someone tell me the size of the set screw of spur gear in a stampede motor.
It appears to be 1.5mm while mine looks already rounds off, just need confirm.
Also, in case it rounds off, how to pull the gear off the motor shaft?
Old 06-25-2011, 03:40 PM
modeleryang
Default RE: urgent help needed - stampede
my stampede is old brushed 2WD version, now the motor has problem.
it seems rotor inside the motor is spining, while I can hold the shaft still (no spinning) by force.
is that because the shaft and rotor are detached to each other? but i need to take off the gear first to see the motor.
thx
Old 06-25-2011, 03:41 PM
Foxy
Foxy's Avatar
Is the picture of the part you mean? If so, that's a pinion, not a spur. I can't be sure the size on that truck as I have not owned one, but as for getting out, the best thing to do is drill it out very carefully with a 1mm bit.
Old 06-26-2011, 04:14 AM
The Mad Modder
The Mad Modder's Avatar
Next time you post a question about your traxxas stampede, please post it in either of the below sections. This is the Tamiya section, not traxxas.
[link=http://www.rcuniverse.com/forum/forumid_147/tt.htm]Electric offroad[/link]
[link=http://www.rcuniverse.com/forum/forumid_251/tt.htm]Traxxas monster trucks[/link]
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
