Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
jugg tranny
Old 10-07-2009, 09:50 PM
DeLeon79
Default jugg tranny
hey guys...im new to tamiya products...i was wondering where you can find jugg parts?? my tranny is grinding REAL bad...and im trying to find parts for this truck.
tried ebay...no luck just alot of clodbuster parts...now...i was wondering...can the clod tranny work? wait...its diffrent right? so well the clod axles fit onto the jugg chassis???? replacing the jugg axles for the clod axles is it possible????
i may just get rid of this truck b/c im having a hard time finding parts for this truck! ugh[:@]
Old 10-08-2009, 07:24 AM
The Mad Modder
The Mad Modder's Avatar
Default RE: jugg tranny
From the sounds of it, you may have gotten a juggernaut 1. They had transmission and axle problems. The bevel gears in the top of the axles would strip from lack of enough support for so much torque. After seeing the problems, Tamiya discontinued the jugg1 and replaced it with the jugg2, which was built MUCH stronger. Here's a few things that you can check to see if you have a jugg1.
Jugg 1's have:
1999 molded on the trans and axles
top axle covers that have a "riveted panel" molded on the top
trans that doesn't have 2 aluminum plates (heat sinks) bolted to the rear of the trans, should be 1 small one on top fastened with 1 screw and a larger one below it using 2 screws.
Jugg 2's have:
2000 or 2001 molded into the axles and trans
no molded "panel" on the top of the axles, just reinforcing ribs
heat sinks(as described above) on rear of trans
Tamiya had service packs that would convert a jugg1 to jugg2, however since the jugg has been discontinued for so long, Tamiya no longer makes them. Sometimes you can find them on ebay.
Let me know if you ID'd it as a jugg1 and I'll put together a list of what parts you'll need to convert it. It is possible to mod clod axles to it, however jugg/txt axles and drivetrain are stronger.
Old 10-08-2009, 07:31 AM
The Mad Modder
BTW, if you're interested in seeing my jugg2...
http://www.rcuniverse.com/forum/m_90...tm.htm#9032221
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
