Evolution of the MGT or great marketing to get the consumer to buy the same truck over and over?
#126
IL
RE: Evolution of the MGT or great marketing to get the consumer to buy the same truck over and over?
Okay, maybe I am starting to hate the MGT 8.0.[:@]
Tried something new with the turnbuckles - Tmaxx short inner end and Savage long outer end...
Went out to try it and now the engine has an airleak.
[youtube]http://www.youtube.com/watch?v=5lTDec5JRT4&feature=player_embedded[/youtube]
#127
Hmmm.... its amazing that it has that immediate effect. Might go and run that test on the MGT as well when I flash it up again. Cheers for sharing mate.
#128
slayerdude i was wondering how did you get your mgt 4.6 to stop clunking when you hit the throttle. I've been trying to figure this out for a week now and im so confused i noticed you got yours to stop some advice would be very appreciated. [] was it the FOC ?
#129
IL
I have the 8.0 but yes it was the FOC that got rid of the hard engagement.
Also - haven't messed with the 8.0 since my last post, been racing my D8T truggy with the ERCM modded JL .21 and ERCM 221T truggy side bleed pipe.
#130
Been putting the XL through its paces. Wheels are great, and oiled diffs work a treat..!! Still cant get rid of the flat spot though. Totally sealed up the engine, and tuned. It clears out, but tends to bog around low-midrange rpm, yet gets a fluctuating idle like its lean, but has heaps of smoke. Dunno, cant wait to fit the LRP.32.
#131
sweet i am going to try that FOC this week its been drivin me nuts thanks for the help
#132
slayerdude i have a question my truck is makin this loud clicking noise when i nail the throttle with a loss of power from my rear wheels and the front pulls alot harder do you thinks its my diff ?
#134
yeah i checked all of that first.......i found a bad bearing would this make the clicking noise ?
#135
IL
Yup, bad brg on the diff will allow the diff gears to disengage and skip.
#136
Do you still have this chassis? I would like to buy this chassis from you or can you make one like it?
#137
TX
Great to see the MGT is still being talked about! Took a new job and haven't had time over the last two years to fiddle much with my nitros! Living thru you guy's lately, great stuff!
#138
ORIGINAL: driller2948
#139
TX
Are you modding the original AE knucks or RPM? A bigger bearing last much longer! I run ProTek R/C 8x16x5mm rubber sealed wheel bearings you can get (10) for $10.00, and they don't seem to wear out!
#140
Cheers mate. ;-)
#141
Wow...it's been so darn long since I was last on here. I've moved house, so everything was packed away and all projects stopped. But back into it now. Well, the knuck-mod as turned out to be pretty fiddly, but am almost there. Just getting the delrin retainers machined up now, but have the rest done and all the parts sourced. Pretty expensive and for what it's worth.... the SavageXL.... she bend, she don't break..!!! Light, flexible, I smash the hell out of that thing, but the MGT, it's "badass", but it's sheer weight will always break something. I've even severely bent steering arms etc, I'd hate to know what the servo condition is like.
#143
I know it may not interest many people no more but if anyone wanted to finish their MGT Knuck-mod off, I have some Delrin retainers available. I have enough for about 9 MGT's at present.
