Mgt 3.0 nitro
Mgt 3.0 nitro
My 3.0 nitro team associate has reverse switch on the controler but didn't have the serval to switch it now I put the serval in and pluged it in turned the truck on aswell as the remote the gas ,break, and steering works but the reverse does not now is there somthing that I need to do to match the remote to the truck to get the reverse to work this is my first time on here I hope I'm doing this properly thanks Brian Williams
lever itself,somewhat like synchronizing them together,also,there might be a reversable switch on the transmitter.
I have that truck,but its been awhile since I had it out.I would have to get it out an look at it to see,an give
you better info.
into the throttle or steering spot,an see if the servo works.
Well I did as you said and now I have a servo on order the servo that I had did not work thanks for the advise now my 4.6 mgt just ordered a block crank piston and sleeve and a new carb I'm not sher about the fuel I'm to use would you happen to know and thanks again for all the help I can't wait til the snows gone to run it thanks again
