Monster GT anyone have one?
#8901
AL
RE: Monster GT anyone have one?
take the bolts out the engine mount from under the truck ,far has if the engine will fit the stock mount take a picture of it am not sure because when i put my bigger engine in my truck i order the big block kit which came with the mount but my truck was the mmgt 3.0
#8903
NC
Finally got a chance to get to theLHS topick upsome new springs and a heavier shock oil. Went with the red/copper combo, with 40w oil and the 2-hole pistons. I ran it a bit with just changing the springs. Major help right there. Gonna run it again tomorrow after doing the rest and see what I think.. Here's some pictures. Don't mind the blue paint on the truck, ran intoa paint canat about 15mph. It had rained earlier and I decided to go out and play after it stopped. That's when I found out it was running rwd. I sheared the front trans outdrive pin.
#8908
My Feedback: (31)
KY
Those shocks look awesome! [8D]
And if i am seeing correctly.... Did you drill the center of a stock 8.0 wheel out and use a 23mm truggy style adapter on it? I have been wondering if that would work or not. Was drilling the axle hole bigger the only thing you had to do?
#8909
TX
ORIGINAL: cummins driver
#8910
My Feedback: (31)
KY
What thunder tiger parts are you talking about? 17mm wheel, or hex?
I like the idea of 23mm wheels with a full size truggy style adapter. You'd be real hard pressed to ever strip those buggers
#8911
TX
Sorry! Yes I was talking about the TT 17MM wheel hubs! I'm not even sure where you can get 23mm any more! Dace is gone, Integy, Losi, Cen maybe?
#8912
What's a good website to get parts for the MGT? Everything out there is for the MGT 8.0 or 4.6. Or are the parts interchangeable?? Sorry I'm new to the hobby.
#8913
TX
MGT has three versions the first was .21, second .46 this version engine upgrade and supposedly had steel transmission gearing but the few versions I opened up in fact did not! It was preceded by the 8.0 .50 engine upgrade, steel gear transmission, steel spur gear with carrier, new wheels, body, and a few other things.
All the parts are interchangeable! I didn’t care much for the .50 engine, but the new transmission and steel spur gear was a need improvement. My .28 Picco would shred the standard tranny!
What are you needing to do?
#8914
I have the .21 So far with out really tearing into at all I need. Front shock tower,fuel line,primer,air filter,front bumper, battery cover for the remote and I know something is wrong with the front drive shaft. It's been sitting for 7 years so I'm going to have to clean it. I put batteries in the controler and it seems to work so that's a plus!
