Go Back  RCU Forums > TEAM RCU > TEAM RCU - Mike McConville
Reload this Page >
How to seal the control surfaces?
TEAM RCU - Mike McConville Ask expert Team RCU pilot Mike McConville questions in this forum.
Old 10-03-2004, 04:28 PM
JuanSG
Default How to seal the control surfaces?
Hello Mike!!!
I'm building a CAmodel Extra 300L 2360mm (31%). It's TOP HINGED.
I've read in some manuals and forums that I should seal the control surface gaps, but I haven't found any info about what is this process exactly.
What I have to do? How I have to do it? What I have to do it with?
Do you have any photos/ draws/ instructions...?
Thank you very much
Juan Sánchez
www.acro3d.com
Old 10-04-2004, 12:06 PM
MMcConville
Default RE: How to seal the control surfaces?
Its very simple. I use clear (Transparent) Ultracote, and iron in a strip from the bottom. Just be sure the surface id deflected all the way up so the seal doesnt impead the movement.
Old 10-04-2004, 12:13 PM
janatle
Hello!!
Just take a piece of covering, fold the covering down the center with the adhesive side to the outside
making a sharp crease at the fold. Use a ruler, measure 1/2 " from the folded crease and mark two places with a pen.
Use a sharp blade and a straight edge and cut through both layers of covering at the 1/2" marked.
Mark and cut to the overall length. This piece will be inserted and ironed down into the hinge bevel.
Place the folded crease side into the center of the hinge line and fully deflect the rudder and ironed the strip down.
Hope this helps You!
Old 10-04-2004, 12:20 PM
JuanSG
Thank you very much
Only ONE QUESTION:
I have to seal the entire control surface gap with only one strip? That is to say: I have to seal over the hinges too? or only between each pair of hinges?
THanks a lot
Old 10-04-2004, 12:32 PM
MMcConville
I seal the entire gap. As long as you are stopping any air leakage, it isnt really important how you do it.
Old 10-04-2004, 12:54 PM
JuanSG
Thank you very much
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
