Go Back  RCU Forums > TEAM RCU > TEAM RCU - Mike McConville
Reload this Page >
NEW Hangar 9 85cc SU-26MM Sukhoi
TEAM RCU - Mike McConville Ask expert Team RCU pilot Mike McConville questions in this forum.
Old 01-26-2008, 10:55 PM
  #51
Airbike
Default RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Hi Mike,
Do you (or anyone else) have a link to the manual for the Su26? I couldn't find it at Horrizon's site.
Thanks.
Old 01-27-2008, 10:32 PM
  #52
MMcConville
Doesnt look like the manual has been up on the web-site yet.
Old 01-29-2008, 01:01 PM
  #53
MAGICSWANSON
Yes, manual please!
Old 01-30-2008, 12:44 AM
  #54
Andrew_S
My Feedback: (12)
Andrew_S's Avatar
Did I see the expected date is now March?
Old 01-30-2008, 01:42 AM
  #55
kochj
I beleave that there has been a Major delay in Ultracote production do to the China's Hollidays......
Newyear and Christmas.....
I beleave they shut down all productions for quite some time....... 3-4 weeks?
Not sure on the facts of this thought....
Old 01-31-2008, 11:56 AM
  #56
MAGICSWANSON
Manual:
[link=http://www.horizonhobby.com/ProdInfo/Files/HAN1225_Sukho_SU-26M-Manual.pdf]Sukhoi manual[/link]
Doug
Old 01-31-2008, 03:18 PM
  #57
Airbike
Thank You very much for the manual....
I just need some 1 1/2" servo arms and maybe some 3/16" axles.
Everything else is just waiting in a box.
Under the "Contents of the Kit" it lists a 4 1/4" spinner. If that's true, this plane is a super value...but I'm guessing probably not....
Can't wait....rumors are that they are at the distribution centers right about now. So it depends on where you hear the rumors from.
Old 01-31-2008, 03:41 PM
  #58
MMcConville
The spinner is not included. The rumor is also not true.
Old 02-02-2008, 01:53 AM
  #59
kochj
The plane looks fantastic....
Must be a blast to fly with the recomended setup of 80-85cc with a can installed!
Great job Mike M. !
Justin
Old 02-05-2008, 07:11 PM
  #60
lsnover
My Feedback: (19)
Mike:
Are you running the Lipos with a regulator to 6v or do you run them straight in a full voltage?
Lee
Old 02-06-2008, 12:29 PM
  #61
MMcConville
I've experimented with both battery set-ups
Old 02-06-2008, 10:31 PM
  #62
lsnover
My Feedback: (19)
And what is your preference? Is there any problem running these servos on 2 cell lipos without a regulator?
Lee
Old 02-09-2008, 08:43 AM
  #63
taygher
taygher's Avatar
Mike,
Do You think the H9 SU-26MM with a Moki 150cc radial engine would be a flyable combination?
(Ref. to my previous post #50)
Lars
Old 02-11-2008, 01:12 PM
  #64
MMcConville
No experience or info on that engine so I cant say.
Old 02-11-2008, 03:17 PM
  #65
taygher
taygher's Avatar
Mike,
The Moki 150 weighs around 9,15 Lbs (4300g) so it is much heavier than the DA-85. I believe it would be possible to balance the plane by placing batteries etc. as far back in the model as possible. My main concern is if the increased wing loading is a problem or not. Since the SU-26MM is your design perhaps you can tell if the planes structure is strong enough to handle the increased weight?
I have seen the previous version of the H9 Sukhoi with a Moki radial engine on it somewhere on the internet, unfortunatly there were no info about the flight carachteristics or the models performance. This plane/engine-combination is not the most common one and there is not much information to find.
Lars
Old 02-11-2008, 03:42 PM
  #66
Didg
Lars,
Did you get my PM?
Old 02-11-2008, 04:12 PM
  #67
MMcConville
Wow, that around the same weight as the DA-200 in my 43% 260. I would say no, its not a good match. The SU-26MM will balance perfectly with a DA-85 in the nose, the rudder servo in the tail and the rx batts under the canopy. It would take something like an additional 2 lbs in the tail to balance the model, so the OA weight would be approx 7 lbs heavier than it should be.
Not good for the airframe and I dont think you'd be happy with the performance at that weight.
Old 02-12-2008, 11:08 AM
  #68
taygher
taygher's Avatar
Mike,
Thanks for your feedback. I was a little concerned that the increased weight (much increased) would be a problem.
My goal is to build a scale-aerobatic plane with the Moki radial engine on it, so I will continue my search for a suitable model.
I still think the H9 SU-26MM seems to be a sweet plane and by the look of the manual very well constructed.
Didg,
I am out of the office for a couple of days and cant check my e-mail adress connected to rc-universe. I will surtainly check for your PM when I return on thursday.
Lars
Old 02-13-2008, 09:21 AM
  #69
ScaleKing
ScaleKing's Avatar
Mike
Can we get your response to post #62? Could you make it detailed please? New to all this!!
Thx
Lawrence
Old 02-13-2008, 10:34 AM
  #70
ScaleKing
ScaleKing's Avatar
What size wheels do you use with those 3x16 axles?
Old 02-13-2008, 02:08 PM
  #71
MMcConville
Dont have a response. Still playing with it and have not formed an opinion yet.
Old 02-13-2008, 02:34 PM
  #72
ScaleKing
ScaleKing's Avatar
Ok but in your hook up you said you used 2 4500mah lipos on the rx and another 4500 on the ign. You used a y harness for the rx batts? runing 6v? no regulators?
Old 02-13-2008, 04:38 PM
  #73
MMcConville
No Y harness. Both run through a seperate switch and into different ports in the rx. One into batt port and one into an open channel (Its all a common power buss) same as I've done for years with a single rx in large models. No regs, but I dont yet have an opinion as to unregulated 2 cell lipo vs regulated to 6V.
The ignition has a reg because the Desert AC ignition isnt made to work above 6V.
Old 02-13-2008, 04:43 PM
  #74
ScaleKing
ScaleKing's Avatar
Thanks alot Mike
This is my first time chating with you! Can I get your autograph!!(LOL) It's nice talking directly to the man that made the planes you love to fly. Great job with all the H9 fleet.
Lawrence
Old 02-14-2008, 08:31 PM
  #75
RICK9303
My Feedback: (172)
MIKE, I down loaded the manual for the Sukhoi, and I don't see anything on how the choke is operated, as the carb is in the motor box, and the canister would be below the carb. Could you describe how you got around this. Did you put another servo on the other side of the tank? It would sure be nice to see some shots of the MtW110 canister in place with the cowl off. The shots of the canisters installed, both infront, and inside the fuse, was a big selling point, for me buying the 35% H9 Extra 260. You know the saying a picture is worth a thousand words.
Thanks Rick
