Original H9 33% Extra CG
My Feedback: (9)
Mike (or anyone else who happens to have a manual) I need the CG point for the Original Hangar 9 33% Extra. I went to Horizon's website but didn't have much luck locating a PDF version.
IA
I have a PDF copy of the manual for the original Extra 300L by Hangar 9.... email me, and I will reply with the attachment.
[email protected]
The balance info is as follows: Page 31 of the manual...
Step 1. On the top of the wing tips, measure back 4-1/2" and 5-3/4"
from the leading edge and mark both places with a felt-tipped
pen. This is the recommended center of gravity (C.G.) range.
Step 2. Fully assemble the model. With a helper, lift the
airplane with your index fingers to find the balance point. The
balance point (C.G.) should lie between the two marks on the
wing tip. If not, add the necessary weight to the nose or tail to
obtain the correct balance.
...hope this helps you out.
[email protected]
