Hanger 9 SU-26 Questions
CA
Hi Mike I have a few questions about the SU-26
1. What hitec servos should be enough for the SU-26?
2. How many servos should I need?
3. Will the airframe take a good amount of stress. (please be honest I don't want to blow an airframe apart.)
I'm not familiar with Hitec servos so I cant answer that one.
Youlll need 5 or 6 servos depending on what you use on rudder. Its fine with one 8611A or 8711, if you use less servo you'll need two.
As for stress, thats hard to say seeing how overly abusive I see some pilots fly GS models. I havent been able to break it.
AZ
EPflyer12...Here are a couple of pics of my Sukhoi and the equipment used…
1. Servos:
• Rudder= [email protected] DS8711 or (Hitec [email protected] HS7955TG)
• Ailerons= [email protected] DS8611A’s or (Hitec [email protected] HS7985MG’s)
• Elevators= [email protected] JR DS8611A’s or (Hitec [email protected] HS7985MG’s)
• Throttle= JR [email protected] DS8417 Or (Hitec [email protected] HS5625MG)
2. Batteries & Electronics…
• [email protected] Cermark 2700Ah, 6volt batteries (2 for Power ExpanderPro, 1 for Ign Module)
• [email protected] Smart-Fly Power ExpanderPro Plus
• [email protected] Smart-Fly Super Switches w/ Deans HD Jacks
• [email protected] Smart-Fly FIOS Ign cut-off Switch
If you want a detailed look into the building of this great airplane, you might want to check out my build thread at this link…[link=http://www.rcuniverse.com/forum/m_7846501/mpage_1/key_/tm.htm]Building the new H9 Sukhoi SU26MM[/link]
Good Luck and if you need help, just post it up and I’ll try to give you a hand!
1. Servos:
