RCU Forums
-   Test Posting Forum (https://www.rcuniverse.com/forum/test-posting-forum-72/)
-   -   copy and paste test (https://www.rcuniverse.com/forum/test-posting-forum-72/8604725-copy-paste-test.html)
RC_Basher20 03-22-2009 06:16 PM
copy and paste test
Reduced: 80% of original size [ 800 x 600 ] - Click to view full image
more info
http://forums.thetoyz.com/index.php?showtopic=16252
More info
I have spent $346.47 including upgrades and the truck
Losi Micro T Blue rear aluminum shock damper tower (item# TM030 Blue) $9.99
Aluminum Micro Desert Truck front shock damper tower. (item# DM028 Blue ) $9.99 x
Losi Micro T blue aluminum front wide bumper skid plate (item# TM003F/L Blue $7.99
Losi Micro T blue aluminum steering rack drag l ink (item# TM049 Blue) $7.99
Rear Pivot Block Set, Aluminum: Micro-T/B/DT $14.99
Front Pivot Block Set, Aluminum: Micro-T/B/DT $14.99
Losi micro T blue aluminum front arms (item# MCT5506) $8.99
Micro T Blue r aluminum front C-hubs caster blocks (item# TM019 Blue) $8.99
Losi Micro T blue aluminum Front bulkhead upper cap (item# TM012A Blue) $10.99
Losi Micro T blue aluminum rear camber link (item# TM057 blue) $3.99
Losi Micro T Blue aluminum Front Steering block knuckle (item# TM021 Blue ) $8.99
Losi Micro T Blue aluminum front camber link (item# TM054 blue ) $4.99
Blue aluminum Losi Micro T rear arms (item# TM056 Blue ) $9.99
Losi Micro T Chrome oversized rims and Tires 4pcs (item# WH-10/SI) $9.99
Team Losi Micro T Screw & pin set (item# LOSB1524) $3.99
Team Losi Micro T shock damper set (item# LOSB1522) $4.99
Losi Micro T blue aluminum rear hub hubs (item# TM022 Blue ) $8.99
Losi Micro T sealed wheel ball bearing bearings (item# TOYZ02) $6.99
Losi Micro-T BB Motor II (Dual Ball Bearing) (item# MO-016) $14.99
Mini T , Baja , Desert truck , RC18 series Jump Ramp (item# LOSB1012) $5.99
Losi Micro T hardened steel front and rear threaded wheel shafts (item# TOYZ10) $13.99
Team Losi Micro T, Baja, Desert truck stand (item# LOSB1603) $2.99
Red Team Losi 1/36 Micro-Desert Truck RTR (item# LOSB0233 Red) $89.99
