Switch harness for raptor 50
Hello, I recently ordered a switch for my raptor, but it was a little too big, are there ones that fit perfectly that you guys know of, that I can order.
Here's one I found, but I don't know if it fits
JR Deluxe Switch Harness (Gold) - Aerofly Hobbies - MultiCopters - AeroModels - FPV - UAV
Thanks.
Thanks.
flydawg (11-24-2021)
The one I have works fine, but it's a little too big for the frame that it fits in, so I just want to make sure that this one in the link will fit.
so what I know fits is the stock switch that comes with a futuba radio seems kinda' generic. I'd assume that as long as it was a simple replacement to that, it' will work fine. I guess you could get your calipers out and measure the bolt hole spacing just to confirm the standard switch is the same as your aftermarket switch. anyway, should be that easy. Without any effort, I'd 100% order the switch you've shown and know it will fit. HOWEVER if you're not comfortable with that, measure the bolt spacing.
So quick question, where do all three cables plug into from the switch? If I'm right, one goes into the receiver the other in the battery, and a third that I don't know of
the third hangs loose, it's a charger port leave it hang where it's accessible to your charger cable .. perhaps so you don't have to take your canopy off to charge.
