Go Back  RCU Forums > RC Helicopters > Thunder Tiger - Raptor 30, 50, 60, 90
Reload this Page >
Throttle Jockey / Raptor 50 / JR 8103 Help
Old 02-03-2004, 07:44 PM
harrier
harrier's Avatar
Default Throttle Jockey / Raptor 50 / JR 8103 Help
Can someone help me attain the following results from my Throttle Jockey V2, in my Raptor 50 with OS 50, and my JR 8103A radio:
Flight Mode (Normal): governor to maintain 1550 rotor RPM
Flight Mode (STNT 1): governor to maintain 1950 rotor RPM
Flight Mode (STNT 2): governor to maintain 1950 rotor RPM
I wish to not have the ability to turn the TJ off with a switch, but have it on full time in all modes as stated above.
I believe that my gear ratio is 8.5:1 after looking at the stock gears that came with the Raptor 50 which I am using but please correct me if I am wrong on the stock gear ratio on the R50.
Does anyone have explicit information on how to obtain the above results? I have read the documentation on Model Avionics but would like to hear from someone who has used the TJ V2 with my particular setup.
Thanks.
Old 02-05-2004, 04:31 AM
raiki
Default RE: Throttle Jockey / Raptor 50 / JR 8103 Help
I have the throttle jockey on my raptor 30 setup on both a 3810 and a 9X. I only use the flight mode switch but have no governing in normal mode and a seperate rotor speed for stunt one and stunt 2.
I use the governor plugged into Aux3 with the 3810 or aux4 for the 9x. This channel is automatically switched by the flight mode switch. I use 3 mixers to control my speeds. Here is my setup on the 3810 (9x is very similar).
Prog.Mix1
Aux3->Aux3
Point L = 100
point 2 = 0
Point H = 100
SW: F-S2
Prog.Mix2
Aux3->Aux3
Point L = 70 (Stunt 1 rotor speed)
point 2 = 80 (Stunt 2 rotor speed)
Point H = 100 (doesnt actually do anything)
SW: F-S12
Prog.Mix3
Aux3->Aux3
Rate:-> -100% (If you altered this to -30, normal flight mode speed would be 70% and you would have governing in all modes)
0%
SW: ON
Hope this helps
Adrian
Old 02-07-2004, 11:31 PM
Tubes
Tubes's Avatar
I have never used a throttle jockey or a governor but if you do not use a switch to turn it on and off - on all the time you said - how will you idle the engine?
Reuben
Old 02-08-2004, 12:49 AM
raiki
If the throttle channel ever goes below 25% the governor will disable itself. You defeat this in flight mode 1 and 2 but setting all throttle point in the curve to >25%.
In normal flight mode you can start the engine. Throttle jockey will not start governing until the throttle is above 25% AND the rotor speed has been above the setpoint for 1 second.
After you land and then pull the throttle stick low (in normal flight mode) the governor will disable and the engine will idle.
Old 02-08-2004, 11:06 PM
Tubes
Tubes's Avatar
Makes sense to me, thanks.
Reuben
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
