Go Back  RCU Forums > RC Helicopters > Thunder Tiger - Raptor 30, 50, 60, 90
Reload this Page >
My Raptor Glitches Horribly????
Old 07-31-2002, 02:05 PM
Sawyer692-RCU
Default My Raptor Glitches Horribly????
Shan- I think you nailed it. I took the horizonal stab mount off and sure enough, the screws were too long and were grinding into the boom. I shimmed it with washers and flew it outside for a couple minutes until it got too dark and all was well. I hope that solved it. Ace should tell buyers of this frustrating problem. I'm also going to take everyone elses suggestions as I want to rule out everything. Thank you guys. All Raptor owners should read this thread.
Mike
Old 08-03-2002, 11:54 AM
invertman-RCU
i had a similar problem with my raptor.
if you look at your tail boom supports,
its a good idea to put some some servo grommets between
the head of the screws and the supports.
put a washer on the screw first, then the grommet.
that solved my glitching.
or like the other guys said.
you could have a bad filter in your reciver.
good luck.
Old 08-07-2002, 10:45 PM
Mad_Scientist
Sawyer692: please remove the other 2 boom support screws and patch the holes in the side of your fuel tank.
Old 08-08-2002, 01:48 PM
Sawyer692-RCU
I have heard of the fuel tank problem so during assembly I checked to make sure the screws were not too long and everything looked good. I'll shim those to though just for good measure.
Old 08-12-2002, 03:45 PM
crash1953
One other thing you should check on your rappy is the battery ..You should be using heavy wire to your radio .. Sometimes you get a voltage drop for just a short sec or two and it will act like a glitch .. I have had this happen on a couple of my raptors .. Especially when using digital servos .. You also need to run as big a battery pack as you can get .. At least a 1400 milliamp or more ..
