Mavrikk Header Tank
Old 09-22-2004, 12:50 AM
-pkh-
-pkh-'s Avatar
Default Mavrikk Header Tank
OK... So I crashed my 50 for the first time (after 115 flights)... and I'm rebuilding... HeliProz didn't have the stock header tank, just the Mavrikk header tank kit with a Hayes fuel tank and an aluminum bracket... problem is, this thing has two pressure nipples (in addition to the clunk fuel line nipple), the original just had one pressure nipple (connected to the main tanks clunk line nipple).
What am I supposed to do with this second nipple? I'm guessing that's for a separate fuel filler line or something. Below is a pic of the new header tank that I'm talking about. I'm pretty sure the top-left nipple should go to the main tank... the next one down is the one I'm confused about. The big one at the bottom-left is where the black clunk line nipple gets installed (gets connected to the carb).
Old 09-22-2004, 02:24 AM
Charlie
Charlie's Avatar
Default RE: Mavrikk Header Tank
Your right, it's for filling your tank. It is sealed over, so you don't have to use it if you don't want to. If you do want to use it, you need to take a small drill and drill it out. If you do use it for fill your tank, make sure you have a shut off valve on the fuel line going to your carb, if you don't, it will flood the carb when your fill it up.
Old 09-22-2004, 07:44 AM
-pkh-
-pkh-'s Avatar
Ahhh... great! Thanks! I was afraid I'd have to buy a valve for it or epoxy it closed!
