Help!!! OS 32
ON, CANADA
1 Post
Help!!! OS 32
Details:
Rap 30 V1 stock with exception of head which I run with leading edge pitch arms to prevent out of track conditions, OS 32, OS #8, Century 3033 muffler, 15% Cool Power, Pitch range +- 9 degrees. Approx 4 gallons thru motor
Problem:
Engine sags horribly accelerating out of hover. Always has some but is becoming particularily worse. Pulling a simple loop and the engine will sag on the backside when adding pitch and throttle to recover. I have hit the ground twice because of this. I was able the auto out of one but the other caused substantial damage.
Solutions Tried;
Glo plug, fuel, replaced fuel lines, header tank. original head configuration. None of helped thus far. I can't believe the motor is finished after only 4 gallons. Compression is solid, no scoring on piston or sleeve, no evidence of over lean running
Anybody have any thoughts. Help is much appreciated
Problem:
Solutions Tried;
Help!!! OS 32
I'll bet your throttle advance is poorly matched to your pitch curve. check out www.raptortechnique.com to see what I'm talking about.
